Plans: 1. Continue covering the center section wing. Status: The top side is covered with the exception of the scalloped trailing edge. Perimeter tapes and surface tapes to follow next. 2. Paint the white background for the lower wing's cross insignia. Status: Complete. I applied two coats of white paint over the Sea Mist layer on both lower wing's bottom surface (approximately 38 inches wide). A black cross pattee will be added next.
