Plans: 1: Primer coat the bottom side of the lower wings: Status: Complete. Three coats of primer were applied to the bottom side of the lower wings. Note that in the photos the wings have been installed on the opposite side of the fuselage. This effectively turned the wings over to simplify painting them from above. 2: Cover the bottom of the center section. Started: 25% complete. The bottom surface has been covered at the leading edge trailing edges.
