Brief Description: Left & Right Lower Wing Covering
Plans: 1. Cover the lower wings. Status: The right lower wing is covered. Of note is the technique I plan for closing the four inch gap at the fuselage/wing root. I have glued a ribbon of hook & loop fabric onto the rib. A similar ribbon will be added to the fuselage. A five inch ribbon of AL flashing will cover the gap around the perimeter bound by the hook & loop tape and secured with screws at the rear.
