Chris' Web Site
Date:  10-13-2020
Number of Hours:  7.00
Brief Description:  Left & Right Lower Wing Covering
Plans:
1. Cover the right lower wing.
Status: About 20% complete. Fabric has been applied to the lower surface and shrunk to 250 degrees.
2. Cover the left lower wing.
Status: About 25% complete. Fabric for the top surface was glued to the leading edge. It will be pulled and adhered to the rear and side edges next session. The tie-down bolt required a hole to pass through the fabric into the frame. The location was reinforced with a small circle of fabric.
Right Lower Wingtip
Right Lower Wingtip
Right Lower Wing Root
Tie-Down Interface Reinforcement
