Brief Description: Left & Right Lower Wing Root Fairing & Covering
Plans: 1. Cover the left lower wing with fabric. Status: The bottom surface was covered and shrunk to 250 degrees. The passage for the N Strut was reinforced around the perimeter with fabric. Note that when the upper surface is covered the fabric around the passage needs something solid to adhere to. The felt underlayment is not very strong and will peel away. This reinforcement bonds the felt to the inside surface of the leading edge.
