Chris' Web Site
Date:  6-26-2020
Number of Hours:  5.00
Brief Description:  Oil Cooler Mount
Plans:
1. Mount the oil Cooler.
Status. 50% complete. The oil filter adapter has been installed. The right radiator mount has been modified to accept the 14" width of the oil cooler. Three of the four corner brackets are complete. The inlet and outlet hoses still need their length modified to finish the installation. Physically there was reasonable room for the hoses to clear the muffler. There is also room to locate the cooler behind the radiator. It remains to be seen if the airflow will be adequate to cool things down a bit better. If this location fails to work well I will need to try a different spot.
Oil Filter Adapter
Oil Filter Adapter
Oil Cooler Rear
Oil Cooler Rear
Oil Cooler Top
Oil Cooler Top
