Chris' Web Site
Date:  6-12-2020
Number of Hours:  4.00
Brief Description:  Cross Patee Insignia
Plans:
1. Continue engine break in.
Status: Ongoing. I ran the engine for another 10 minutes at 3000 RPM with the cover in place. Unfortunately the oil temperature is running very high at 250 degrees. I have decided to install an oil cooler to mitigate this concern. Ideally I would like to see something closer to 220 degrees under load. That said the coolant is running stable at 210 degrees.
2. Paint insignia onto the rudder.
Status: 50% complete. I decided to go with the cross pattee insignia. While rarely used on a DVII as is a streaky finish it is still true to the period.
Cross Pattee 1
Cross Pattee 1
Cross Pattee 2
Cross Pattee 2
Cross Pattee 3
Cross Pattee 3
