Plans 1. Patch a hole in the engine cover. Status. 50% complete. I need to close a small hole that developed in the engine cover. The metal got a little thin and cracked. I have reinforced it with some glass and epoxy on the back side. I will need to touch it up on the outside later. 2. Add a protective shield behind the chair. Status. Complete. I added a small section of PVC pipe for protection where the chair rubs on the fuselage rib. My DAR recommend. Done. 3. Drill quick links for cotter pins. Status: Complete. The control cables are connected at the terminal ends with quick links. My DAR recommended I drill the links to add cotter pins. Done.
Note: The anti-chafe tape appears to be unsticking. The glue is too weak to hold. I will need to switch to a different brand.
