Chris' Web Site
Date:  4-1-2020
Number of Hours:  4.00
Brief Description:  Upper and Lower Cowl.
Plans:
1. Continue the cowl fabrication.
Status: 90% complete. Bonding of the airflow block for the upper cowl is complete and the assembly painted. A four inch hole for passing the propeller extension has been cut as well as cuts to create a removable panel. The panel is required to make the cowl removable without removing the propeller. Plate nuts will be added next session.
2. Engine test run.
Status: Complete. I run the engine for about 30 seconds once a month to keep things lubricated. Today was that day. It fired up quickly and sounded great with the muffler attached.
Cowl with Airflow Block Front View
Cowl Side View
Cowl Side View
Propeller Extension Cutout
