Plans: 1. Hook up the fuel pressure sensor. Status: 50% complete. Since the sensor is in the engine compartment I wanted a connector inserted in-line. I was eager to mount the engine so I only installed the connector on the firewall side today. 2. Engine fitment check. Status: 25% complete. In preparation for engine mounting the mount's bolts were torqued. The engine was hoisted and lined up with the tangs and secured in place. After tightening the bolts for the bushings they turned out to be 1/2" too long. I will need to replace the hardware with shorter bolts next session.
