Chris' Web Site
Date:  1-16-2020
Number of Hours:  4.00
Brief Description:  Fuel Sensor Cable and Engine Mount Extension
Plans:
1. Hook-up the fuel pressure gauge.
Status: 80% complete. The electrical connection to the fuel pressure gauge is slightly complicated. The instructions require a shielded cable for both the power and signal lines. Additionally a 9 pin D connector is supplied instead of push pins. Hooking up the D connector was straight forward but took some time. The cable was then wraped with sleeving and routed to the sensor's location at the firewall.
2. Notch the engine mount extension to accommodate the tangs and bracket.
Status: Complete. The extension to the engine mount needed to have notches cut into it to allow for passage of the tangs and some hardware.
Fuel Pressure Sensor Connector
Fuel Pressure Gauge
Fuel Pressure Gauge
Engine Mount Extension Support Bracket
