Brief Description: Fuel Pump Manifold Clamp and Engine Wiring
Plans: 1. Add a clamp to the fuel intake manifold. Status: Complete. In addition to adding the clamp I removed the fuel filter spring clip and bracket. The clamp alone held the assembly very securely. Between the clamp and bracket a preload was being applied to the fuel tank outlet pipe. Removing the bracket relieved the tension. 2. Add insulated thumb screws to the power bus covers. Status: Complete. The bolts that held the power bus cover in place were replaced with non-conductive thumb screws. The buses are now completely shielded from above. 3. Continue wiring the avionics. Status: 95% complete. All of the electrical leads into the engine compartment were added with one exception. The fuel pressure sensor remains unconnected.
