Plans: 1. Continue junction panel hook-up. Status: I hooked up the remaining power wires to the terminal blocks. I mounted the Battery bus chassis to the floor. I also hooked up the voltage and current sense lines to the shunt. The on/off switches need to be added to the instrument panel but I am hesitating since I don't have the engine harness in hand. It might force a different layout than I imagine. 2. Install USB charger. Status: Complete. I had originally planned to have a second 12V cigarette jack for the iPad. But since the iPad uses a USB port I decided to nix that and go with USB. It is a large hole but it looks great. The jack supports over 2 Amps on each of two ports.
