Chris' Web Site
Date:  10-30-2019
Number of Hours:  6.00
Brief Description:  Junction Panel
Plans:
1. Continue junction panel hook-up.
Status: I hooked up the remaining power wires to the terminal blocks. I mounted the Battery bus chassis to the floor. I also hooked up the voltage and current sense lines to the shunt. The on/off switches need to be added to the instrument panel but I am hesitating since I don't have the engine harness in hand. It might force a different layout than I imagine.
2. Install USB charger.
Status: Complete. I had originally planned to have a second 12V cigarette jack for the iPad. But since the iPad uses a USB port I decided to nix that and go with USB. It is a large hole but it looks great. The jack supports over 2 Amps on each of two ports.
Avionics Bus
Avionics Bus
Battery and Main Buses
USB Charger Outlet for iPAD
