Plans: 1. Install the battery box. Status: 90% complete. The first attempt to mount the battery box had its own challenges. The fuselage structure needed to be reinforced behind the box to provide a mounting point. And the front of the box needed to be cut away to allow the battery to be easilly installed/removed.
Since the fuselage was built up already it took a bit to tailor the structure accept the box.
