Plans: 1. Add tie down bolts to the lower wings. Status: Complete. To allow the aircraft to be tied down a tie-point was needed on the lower wings. A 3/8" nut was welded to a steel box which was then bolted to the main spar of the lower wing with AN3 hardware. A removeable 3/8" eye bolt is then added to make the connection.
