Plans: 1. Adjust seat back. Status: Complete. I decided to tilt the seat backwards slightly more. I am predicting it needed to be reclined a tad more to be comfortable. 2. Add the remaining leading edge reinforcement to the lower wing. Status: 40% complete. Several tasks needed to happen before I could finish the leading edge. First, I need to remove the N strut to make the area accessible. Second, I need to cut out passage areas for the N struts in the aluminum sheets. Third, I need to fabricate the trim covers for the passages. Fourth, I need to add plate nuts to the sheeting for securing the trim covers. Steps one to three were completed today for the right wing.
