Chris' Web Site
Date:  9-18-2019
Number of Hours:  4.00
Brief Description:  Lower Wing
Plans:
1. Adjust seat back.
Status: Complete. I decided to tilt the seat backwards slightly more. I am predicting it needed to be reclined a tad more to be comfortable.
2. Add the remaining leading edge reinforcement to the lower wing.
Status: 40% complete. Several tasks needed to happen before I could finish the leading edge. First, I need to remove the N strut to make the area accessible. Second, I need to cut out passage areas for the N struts in the aluminum sheets. Third, I need to fabricate the trim covers for the passages. Fourth, I need to add plate nuts to the sheeting for securing the trim covers. Steps one to three were completed today for the right wing.
Temporary Scaffold to Replace the
Temporary Scaffold to Replace the "N" Struts
Leading Edge Trim Plate
Rear View from Right Side
