Plans: 1. Add the leading edge reinforcement to the lower wing. Status: 30% complete. The inner portion of the leading edge reinforcing strip was added to both sides of the lower wing. The outer sections require the fab of some trim plates. I had to momentarily put this off as I need to get some plate nuts from Aircraft Spruce to finish.
