Brief Description: Lower Wing Tips and Root Airfoils
Plans: 1. Fab the root airfoils for the lower wing. Status: Complete. At the point where the lower wings join the fuselage there is a small gap.The span will be closed with a ribbon like section of trim. A partial airfoil has been riveted to the fuselage side panel to provide additional support. The pitot tubes, lift wires and aileron control cables pass through this area so it is helpful to retain this section of the wing as a seperate compartment to ease assembly. 2. Fab the lower wing tips. Status: 50% complete. The tips are installed. Some additional stiffening gussets will be added to prevent bowing due to fabric shrinkage.
