Chris' Web Site
Date:  9-2-2019
Number of Hours:  4.50
Brief Description:  Pilot's Step
Plans:
1. Complete the pilot's step.
Status Complete. The final bracing and shims were added to the root airfoils. The step itself was created using two layers of 1/4 inch plywood glued together. The plywood was screwed into the cradle from the bottom and covered with .020 AL sheeting. Once the wing is covered I will add some friction tape to prevent slipping. Kudos to Sam Buchanan for the inspiration. His version covered the entire length of the airfoil. I vaguely recall him commenting that he regretted making it that long, so I elected to make a smaller version.
1/2" Angle Cross Braces
Plywood Core
Plywood Core
Aluminum Overlay
Aluminum Overlay
