Plans: 1. More Airfoils. Status: About 2/3rds of the airfoils are complete. Today was focused on mounting the root airfoils. They interfere with the compression strut and drag wires. The solution was to make a two piece gusset that sandwiches around the wire and tab. I wish I had done this on the upper wing as I like the result. I also mounted the end airfoils on both wings. Simple enough but it is important to get them perfectly perpendicular and flush with the spar ends. The other airfoils will be spaced exactly 10 inches on center from the ends.
