Chris' Web Site
Date:  8-30-2019
Number of Hours:  5.00
Brief Description:  Lower Wing Airfoils
Plans:
1. More Airfoils.
Status: About 2/3rds of the airfoils are complete. Today was focused on mounting the root airfoils. They interfere with the compression strut and drag wires. The solution was to make a two piece gusset that sandwiches around the wire and tab. I wish I had done this on the upper wing as I like the result. I also mounted the end airfoils on both wings. Simple enough but it is important to get them perfectly perpendicular and flush with the spar ends. The other airfoils will be spaced exactly 10 inches on center from the ends.
Right Root Airfoil
Right Root Airfoil
Two Piece Gusset
Two Piece Gusset
Left Outer End With Spacer
