Chris' Web Site
Date:  8-1-2019
Number of Hours:  4.00
Brief Description:  Ailerons
Plans:
1. Complete the aileron build.
Status: Complete. The ribs were added to the outermost sections. The control horns were added. And the hinges were tweaked a bit for better alignment.
2. Install aileron controls.
Status: About 10% complete. The Teleflex style cables have been temporarily installed to verify alignments and placement. This turned out to be a bit tricky. The cables need to be secured such that the throw in both directions is even at each aileron. Lots of trial and error was involved but it appears I found a sweet spot. A permanent solution will be devised during the next session.
Right End Rib
Right End Rib
Aileron Control Horn
Left End Rib
Left End Rib
