Plans: 1. Build Ailerons. Status: 50% complete. There are no plan details for the ailerons. That said the supplied tubing and cut parts determine the overall dimensions. The placement of the hinges is the biggest mystery. That said I had asked Robert about locating the hinges and his reply led me to place one at the outermost edge. A second about eight inches in from the inside edge. The third roughly mid-span near to the control horn area. I also looked at build photos of other Fokkers for some ideas. The ribs are formed similar to the rudder's construction. I simply drilled out holes at either end of the blank to the tubing dimensions. Then cut and folded along the length.
