Chris' Web Site
Date:  5-2-2019
Number of Hours:  4.00
Brief Description:  Upper Left Wing Section
Plans:
1. Assemble the left upper wing.
Status: 95% complete. After some hassle I was able to install the upper left wing on to the air vehicle. Unfortunately I found that the trim plates interfered with the "N" struts and will need some modifications. There was also some issues with the forward landing wire. So status wise I am taking a hit. Other than that things went well. I riveted the L. E. flashing down after having leveled the wings. This appears to have been a good technique as I found the flashing did appear to shift slightly at the root edge. One down or is it up.
Upper Left Wing Leveled and Ready for Rivets
Installed Upper Left Wing Front View
Installed Upper Left Wing Rear View
