Plans: 1. Continue center section fabrication. Status: We're at 98% complete and holding. I drilled around 50 lightening holes in the outside airfoil stiffeners to reduce some weight. Also, before finishing the trim plates I thought it advisable to completely rig the wings back in place. I want to be sure nothing alignment related would impact the trim cuts. In the process I also found out how easy (it's not) it is to put it all together. The center section is a bitch to install. It will only be worse once covered. Never got to finishing the trim plates today but otherwise it is really coming together.
