Plans: 1. Glue the neoprene trim into the cowl. Status: The epoxy failed, shoe goo failed and PVC raft glue failed. Today I am trying DAP Rapid Fuse glue. This appears promising. After an hour of set time it seems to be holding. I only tested a small section at the moment. I think it might do the job. Fingers crossed. 2. Fab the lower wings. Status: I was able to cut the four spars to length and four compression struts. I did a quick fit check and everything looks okay. It is really neat to see the wings attached even in this simple state. You can finally visualize what it will become.
