Plans: 1. Odds and ends. I needed to add the final brackets to the storage bin. Status: Done. On the opposite sides of the bin I added brackets to secure it to the frame. These brackets will provide a finished look as well as strengthening the installation. Status: Done. I changed the S hooks to a larger size on the cargo net. The earlier ones were a little small to handle easily. Status: Done. Captured a photo of the iPad mount showing the back side. Status: Done. I created a small battery pack that uses AA cells for the VHF radio. 2. Create a rear inspection panel in the fuselage. Status: About 50% done. This panel will be directly below the carry handles and made from transparent polycarbonate. This panel allows inspection of the rudder/tailwheel cables. The photo below shows the frame without the poly and handles installed.
