Plans: 1. Complete brake installation: Status: Complete. I finished up the installation by creating two set screws to clamp the brake cables. 2. Fabricate and install inspection hatchs into the right and left fuselage panels. Status: 80% complete. Adding hatches to the panels requires several new parts to be fabbed. I was able to get the parts cut out and some assembly done today. The panel openings were cut. Doors were cut out as well as backing plates for the doors and hinges. Next session I will be adding latches to the doors and finishing the assembly.
