Plans: 1. Install tailwheel. Status: Complete. I decided on the method to install the MATCO tailwheel. I purchased some aluminum channel with an internal width of about 1.25 inches. The same as the tailwheel springs. I then created some mounting plates to bolt the channel to the fuselage. It seems to be working well. I am wondering however if I should add an additional spring to stiffen the first spring. It appears to be fairly bouncy with just one. 2. Remount the painted wheel covers. Status: Complete.
