Plans: 1. Install remaining fuselage ribs. Status: Complete. 2. Begin landing gear assembly. Status: Started the assembly of the landing gear legs. The process is to reuse the fuselage layout as a guide to cutting the correct angles. Which I did. After a test fit, I am not finding that the gear's layout dimensions are falling into place. I am not sure exactly where the issue is yet.
