Status: Complete. Hopefully three is a charm. This is the third time I fabricated the brackets. I needed to increase the height to accommodate the actual wheel dimensions. My welding is getting better. I drilled the mounting holes on this version. Test fitting with the brakes and wheels went well.
Final assembly onto the axel will require some finesse when I get to that point. The bolt that runs through the axel is long and might be difficult to align into the holes. I will find a technique for that next week. I decided not to drill the thru hole in the brakes this week.
