Brief Description: HS skin cut out for the elevators
To prepare the horizontal stabilizer for the elevator fitting, it was time to cut out the skins at the counterweight intersection. I did drill a hole at the desired “edge” and used the snips to cut out the marked dimensions. The finish was done with a small file and sanding paper. It worked nice afterwards. The clearance was given by the rod ends. It was not possible to insert them more because of the doublers installed (SB 14-02-05).
