Brief Description: Primed Elevator Parts labeled and dimpeled
I got all the alodined and primed parts from the paintshop. They worked about 10hrs on the parts (sanding, alodining and epoxy-priming...). To make it easier for them, I did not flute and dimpled the parts before priming. Since the paint is still flexible, there is no problem to do it after priming.
With the stamp I labeled all the parts with the respective partnumber and priming date. I looks very nice and it is easier to pick the correct piece while assembling.
Now I dimpled the elevator skins and the stiffeners. Also the rips are fluted and the angles nicely 90 degrees to the web.
Next step will be backriveting the stiffeners and final drill and dimple all other holes. Starting next week.
