Brief Description: Work on the Horizontal Stabilizer
Working on the horizontal stablizer. All parts have been deburred and final drilled and finally I clecoed the whole stabilizer. It was an easy way using the scotch-brite deburring wheel to break the edges of the rear spar reinforcement bars to make the faces rest against one another. Front and rear spar were final drilled easy cause of the pilot holes. The flutened rips have been match drilled and the skin clecoed on the rips and spars. It is nice to see the full dimensions of the horizontal stabilizer. It looks like an aircraft already
