Brief Description: Horizontal Stabilizer - first view
I clecoed the horizontal stabilizer just to view the dimensions. It fits just right. Not much space left, but enough to work on it.
I saw some filiform corrosion on the spars that needs to be removed. Also all of the hinge bracket show some filiform corrosion. I need a way to get rid of the paint on the hinge brackets. I will removed the filiform corrosion and paint it again.
I will finish the HS before priming any piece of the vertical stabilizer, since I have to do it in a professional paintshop.
