Brief Description: Rivet the anti sevo tab together.
This morning i was able to rivet together the Anti servo tab left and Anti Servo tab right. I noticed that the easiest way for me to attach the control horn was to rivet it to the rib first then attach the rib to the skin. This is probably only possible with a ground down rivet puller and using the wedge tool to attach the rib to the skin because the clearances are very tight. However, I think that it is easier to perform this way and it is much easier to inspect.
