This morning I drilled and attached the bracket that holds the left nav and strobe. I still need to flox and epoxy the fiberglass bracket in order to make it fit bettter. I also finished the wiring on the Molex connector for the Nav and strobe. I still need new male 4 pin Molex connector. The original one was messed up when I tried to pull the pins out of mistake that I made while wiring up the connector. I was and still kinda am unsure weather the female pins go one the female connector, If this is the case the wiring harnes is backwards or the drawing is wrong. I dont think that either of those are the case. I ran in to the same issue with the landing lights. I looked all over and I found them done both ways. I am going with the prints are right and the harness that vans sent me is right, I wirred the right nav and strobe the same way and it seemed to make good electrical connection. Perhaps it doesnt matter.
