Brief Description: Attatch trailing edge to ribs (left Wing)
Today I attached the trailing edge the the aft ribs on the left wing. I originally installed a LP4-3 rivet on the flapperon hinge bracket. I realised my mistake and drilled it out for a new rivet. When the new rivet went in it did not set flush the way that I expected. I Emailed Vans Aircraft concerning this issue. The responce was that it was not a problem and I should continue on with the build.
