Today I installed the wiring for the stabilator trim servo. The red line on the wire lines up flush with the plastic gromet on the aft bulkhead. I deburred the J stiffiner really well However, I am concerned with it rubbing the wire for the servo. I will be contacting vans regarding this issue.
Late entry
Contacted vans aircraft and they said that this has not been an issue. However I could put some RTV over the edge to protect it if i wanted to. Which has been completed.
