I have begun skinning the tailcone. The middle left and right as well as the upper left and right skins were deburred and clecoed to the existing structure. The static / pitot system was completed up as far as i can with only the tail cone assembly available. The 2 strings were pulled through as pull lines for the control cables for the rudder and the stabilator. Lasty the first set of rivets were installed on both the left and right sides. The next things to do is to install the rest of the rivets and begin deburring the top portion of the turtle deck.
