CASEY'S WEB SITE
Date:  4-20-2018
Number of Hours:  4.00
Manual Reference:  SB18-02-02
Brief Description:  Bolted together stabilator Hinge
The stabilator drag torque on the plated nuts was about 15 in/lbs. So the bolts holding the hinge brackets on were torqued to 40 in/lbs. The stabilator stops were installed and torqued to 40 in/lbs. Also the stabilator skins were clecoed on temporarily.
