Today primed the components that make up the parts necessary to complete service bulletin SB18-02-02. I also primed the (6) HS-1214s so I can complete the Horizantal stablizer. The WD-1222s were aligned and riveted to the front and rear spar of the stabilator. a few scraches were found and the were sanded out with 600 grit sandpaper. They still need to be primed before final assembly. Shop side of the size 4 rivets were between 0.200. and 0.203 this meets mil spec MIL-R-47196A.
