CASEY'S WEB SITE
Date:  3-24-2018
Number of Hours:  3.00
Manual Reference:  SB18-02-02
Brief Description:  Prepare more parts for service bulletin 18-02-02
This morning I deburred HS-1231B, HS-1231C and HS-1231D. The Top HS-1232 is match drilled deburred and ready for primer. Once the bottom side was matchdrilled it was mis aligned and would not fit properly between the rails of the front and rear stabilator spar. However I was able to drill the WD-1207 and WD-1208. So once a new HS-1232 has arrived from vans I will be able to matchdrill it and prime it.
