Nick & Amber's Web Site
Date:  7-23-2022
Number of Hours:  1.75
Manual Reference:  Sec 16iS
Brief Description:  Wiring (Right Wing)
~ Section 16iS: Wiring for light (Right Wing) ~
- Nick ran the wiring harness for the Nav/Strobe & Landing Light wiring through the Nose Ribs as indicated in the instructions - to do so, he removed the snap bushings from the first two nose ribs and cut a slit into both snap bushings, clasped them over the wiring and reinstalled the bushings into the nose ribs.
- Prior to attaching the Green & Black grounding ring terminals to the Nose Rib, removed the primer (by sanding) from the surface area that the grounding wires attach to.
- Marked the grounding wires and screw head with a RED line for a visual reference to ensure the screw/wires have not gotten lose.
Nick's hours: 1hr, 45min
Wires ran
Wires ran
Red mark on ground
Red mark on ground
