CMBAero
Date:  2-26-2012
Number of Hours:  1.50
Brief Description:  Rudder Assy. Finishing
The two bottom R918 rudder attach strips were fabricated from the provided raw material... Then, the rudder horn box was trimmed to final size and clecoed on the structure, the fit was perfect so I went ahed and match-drilled it... Now that the rudder horn was completed, I could clamp in place my two bottom attach strips that were previously built and back-drill them from the top with the prepunched hole in the skin as a guide... Finally, the rudder was completely deassemble to be deburr, dimpled, cleaned and primed for final assembly!
R918 Attach Strips
R918 Attach Strips
Rudder Horn Box
Rudder Horn Box
R918 Attach strips getting installed...
