Brief Description: Preparing hstab spars for structure assembly...
Rear and front horizontal stabilizer spars (HS902 and HS903) were clecoed together with the doublers (HS 906 and HS907)... Both spars and doublers were then matched drilled to #30 holes... Attachment brackets (HS908) also were clecoed, squared and drilled to the front spar (HS902). Finally, outboard hinge brackets (HS912) were clecoed in place on the rear spar and matched drilled to final size...
Horizontal stabilizer spars are now ready to be deburred, countersink, primed and assembled!
