Craigs RV-8 Web Site
Date:  11-5-2018
Number of Hours:  1.00
Brief Description:  Wing Height Spacer
I make up a 2 51/64 spacer to hold the level at the proper height to verify wing incidence. I took a 6 inch piece of 1/8 x 2 inch aluminum that I purchased at a local hardware store and bent it 90 degree angle. I then filed one side to exacly 2 51/64" this was clamped to a level to correctly position it over the rear spar web when the front of the level is over the front of the wing spar web.
spacer in action
spacer in action
