For the switch labels I used a product from Pulsar FX called Decal Pro. The product had a steep learning curve, you definitely have to follow the instructions to the letter and work small. I do have to say once you get the hang of it it works very well. The labels only take a few minutes to make up, are pretty durable but if you need to remove one, alcohol and some rubbing will remove them.
